universal login manger
  • wassem
    • Aug 2012
    • 166
    hi everybody
    i want to ask if i use universal login manger when i send an email then sender will be the user who loged into .
    and if i can use the active directory in logingg (when using the universal login manger)
  • MrB
    • Nov 2009
    • 147
    Re: universal login manger
    ULM can be set to use your AD as well as being set up for a local database
    The user (will have to log on either via a PIN code/ Username & Password or the users swipe card.
    If used with AD, ULM will look at the AD entry, and a "Scan To Myself" box will appear on the "Scan & Scan" Screen.
    • wassem
      • Aug 2012
      • 166
      Re: universal login mangerice
      thanks MrB for reply
      you right after installation of ulm the box of send to myself had appeared
      and when using it in sending ,it does't send and give the communication error #839
      our client using server exchange 2010
      pls any advice or any usefull link if you have experience in using ULM
      • KL568
        _
        • Feb 2011
        • 324
        That #839 seems like a wrong user name/password being use to authenticate the Mail Exchange. Maybe your machine is not whitelist to use the Exchange? Might need your Customer's IT to support you.
        • MrB
          • Nov 2009
          • 147
          Has the device got the SMTP & email address installed in its settings
          Also depending on some networks, that email address may need to have some authentication
          (Ask the local network admin if this is a case, and then ask them to set up a email/user account for the MFD)
