error reset for ir1210
  • rupesh
    • Oct 2007
    • 36
    hi allz can u tech me how to reset fuser code for canon ir1210
    how to inter simulation mode ?
  • Funnyfarm69
    • Jun 2008
    • 51
    You need to press the starry head and then the hash key, then into printer and then reset. Good luck.
    sigpic MINES A PINT!
    • JustManuals
      • Jan 2006
      • 9838
      You should work on your English before you get involved in any Sim codes.
      Paul@justmanuals.com
      • sweet.persona
        Engineer
        • Nov 2009
        • 414
        help me ..problem in my IR1210
        i have ir 1210 when i on this copier she say
        i don't found anysoulution to repair this problem
        A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
        DAMENE ABDEL AZIZ
        DJELFA
        • Funnyfarm69
          • Jun 2008
          • 51
          I have roughly translated this to mean prepare new drum.
          Fit new drum Problem solved!!!
          • sweet.persona
            Engineer
            • Nov 2009
            • 414
            thankyou very much Funnyfarm69 tomorrow we see ur somution
            DAMENE ABDEL AZIZ
            DJELFA
            • montana
              • Aug 2008
              • 392
              hi ....to enter the service mode in canon IR1210 you have to press the additional function head then press ID#go to clear all the machine will initialize.....if it does not work then you have to check or replace the fixing assembly...
              i hope it is help my dear
              • sweet.persona
                Engineer
                • Nov 2009
                • 414
                i replace new tombour but it is the same problem ..
                tomorrow i do that's MONTANA and i tell you
                in the last and not Least thank you very much for all the tech
                DAMENE ABDEL AZIZ
                DJELFA
                • meme
                  • Jul 2009
                  • 10
                  drum error
                  hi..
                  try to open the front door , were you put the new toner ,if it help .
