Canon iR3100 Send Kit
  • mitsubee
    • 176
    Dear all,
    I have a iR C3100 Send ( USB ) dongle with me , but i need some help on this
    item Info , how it works and how do i install it into the iR C3100 machine.
    thanks in advance
  • djbass
    • May 2008
    • 165
    The dongle goes into your PC/Laptop, and requires a driver to be installed which should be on a CD provided with the dongle.
    Also on the CD is the iRC3100 Send Enable Tool, which you run after the dongle is installed on your PC.
    It will ask for the serial number of the photocopier to which you are enabling the send feature.
    With your PC connected to the machine via a network cable follow the prompts within the utility and it will turn the feature on and also lock the dongle to the provided serial number.
    Then restart the machine and the feature will be available.
    No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
    • mitsubee
      • 176
      bro djbass ,
      where can i get the driver as i dont have the CD ? any weblink to download the driver ?
      thanks bro
      • djbass
        • May 2008
        • 165
        Download send tool from here, not sure if it includes the driver or not but I believe that is available from the HASPE website anyway (google it).
        irc3100_send202.zip
        • mitsubee
          • 176
          dear djbass,
          thanks bro i download now..i'll try it out any problem i will ask here.
          thaanks
