Calibrate Canon IR7105 Monitor
  • tinnyjay
    • Oct 2009
    • 655
    Is there any way to calibrate the monitor.
    The touch did not respond to the are i touch it.
    "Who loves the roses,must also bear thumbs"
  • laitang
    • Nov 2012
    • 627
    Re: Calibrate Canon IR7105 Monitor
    Enter service mode,
    COPIER > FUNCTION > PANEL > TOUCHCHK
    • tinnyjay
      • Oct 2009
      • 655
      Originally posted by laitang
      Enter service mode,
      I did it, but still the same.
      If you want to touch for example Paper Select, you must touch about 3/4 inch below to select paper.
        • 2621
        You really need to change the touch pad.
        FK2-1645-000 PANEL, TOUCH
