ir c1030
  • Scottb
    • Apr 2013
    • 303
    ir c1030
    How in the world do you set this to default to black copies. I have looked at the user manual but I must be missing it. i have done this on the 1020 series if memory serves correctly but its been a while.
    Thanks,
    Scott
  • tykesupport
    • May 2014
    • 24
    Re: ir c1030
    Use the Following Steps to change the Default Copy settings:
    1) Press (Main Menu) button.
    2) Use the (Scroll Wheel) to select <Copy>, then press [OK].
    3) Change the Copy Settings to what you want to default settings to be.
    4) Use the (Scroll Wheel) to display <Standard Mode Reg./Initialize>, then press [OK].
    5) Press [OK] to select <Register>.
    6) Use the (Scroll Wheel) to select <Yes>, then press [OK].
    7) The default copy settings have now been changed.
    • Scottb
      • Apr 2013
      • 303
      Re: ir c1030
      Thanks I knew it was something that I was missing. I was trying to go in the the add functions after making changes on the display.
