Error 061 - 001 canon ir5075
  • zelotprotos
    • Apr 2014
    • 36
    [Error Code] Error 061 - 001 canon ir5075
    Dear Friend....
    My canon IR 5075 has 061 - 001 error (I have this error two or three times on the on the other machine )
    Setting : OPTION ---> BODY ---> PO-CNT = 1 : The machine shows that error.
    Setting : OPTION --> BODY --> PO - CNT = 0 : the machine has no error at all. but the copy result has dark background so I tried to set the height of the primary charge and also the transfer charge to reduce the dark background print but it always has the half black background print.
    Some guy tell me that the laser is the problem.
    on my first machine I have bought new laser and fix the problem.
    but accidently this new problem get the same problem again: Error 061 - 001.
    please give me some advice, what 's the wrong ?
    What is the important thing to do when replace the laser?
    thank you.
    • 16083
    Re: Error 061 - 001 canon ir5075
    Make sure laser shutter is working properly and not stuck half way
    Laser Shutter is activated by the pin on the Primary Fan Duct Assembly
    The pin actuates the shutter through the opening in the Machine Front Plate
    Check the shutter operation and the pin on the Primary Fan Duct Assembly.
    If the pin is broken, it should be replaced. The pin can be replaced by replacing the Primary Fan 2 Duct.
    Duct, Primary Fan 2 FC6-3540-000.
    • laitang
      • Nov 2012
      • 627
      E061-001: the drum surface potential (VL2) of the background is 200 V or higher
      Did you replace: drum? potential sensor?
      • zelotprotos
        • Apr 2014
        • 36
        I checked the laser unit but I don't know which part of it named laser shutter , please describe me.
        and also I don't know the pin of the Primary Fan Duct. thankyou
        • zelotprotos
          • Apr 2014
          • 36
          Well, now it's working. the house of the screw driver is broken so I never apply the screw driver there.
          Thank you for giving me how that laser works.
          so, Can I just make a permanent lock on the Laser Shutter? such as give a tape or something to push it and never come back?
          • Canuck
            Tech Specialist
            • 1713
            Replace the rear cover of the fan duct assembly...or....melt a paper clip into the rear cover parallel to it at the broken area to make a small hoop to put a screw through. Works good in a pinch
            • mramlawi
              • Jul 2011
              • 838
              thats what i always do when the Fan base is broken
              Distinguished road makes you jewel in rough
              • ARUN MISHRA
                • 80
                change primary corona assembly ..............
                sigpicARUN KUMAR MISHRA
                • Udai08
                  • Jan 2017
                  • 1
                  clean or Replace Laser Unit, (Meybe Polygon Laser is damaged. You can see in there like a dirty polygon)
                    • 16083
                    Your are replying to a 2014 post.
