ir 105plus error code 602-001
  • jkumar_jaykay
    • Jul 2025
    can anyone tell the solution for error code 602-001 in ir 105plus.there is no parallel port for formatt the hard disk and re install the system softwares and boot rom.usb port is there.how to connect usb to the system and which sst will support .
  • mtech
    • Mar 2007
    • 307
    You connect with a cat. 5 cable. The machine most likely needs a hard drive.
