Canon Imagepress c 6000 (E602-002)
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 170
    [Error Code] Canon Imagepress c 6000 (E602-002)
    We have client that face problem with his machine canon imagepress c 6000 LCD display error code (E602-002) with black display and there is no any response.
    I appreciate your help.
    • 16083
    Re: Canon Imagepress c 6000 (E602-002)
    Hard Drive issue
    U could try the defrag method--power off=hold down 1&9 key,while holding}>power up printer- until u see white blocks dropping on LCD
    If u receive a NG u need to replace HDD & 're load Firmware
    • ARUN MISHRA
      • 80
      teckat is right,,,,,,,,,,,,,,,,
      sigpicARUN KUMAR MISHRA
        • Mar 2012
        • 170
        Originally posted by teckat
        Hard Drive issue
        I do your advice then back to tell you the result.
        Thank you.
          • Mar 2012
          • 170
          Hard Drive issue
          we changed the hard disks, we formatted the hard disks and installed the system and after restarting the machine we get the same result (E602-002).
            • 16083
            Used the SST FORMAT FILE
            where did u get the HDD from
              • Mar 2012
              • 170
              where did get the HDD from[/QUOTE]
              In the beginning we have order hard disks is IDE connection but IPC 6000 is SATA connection.
              so we have order conversion kit from PATA to SATA:
              its F7-0431-000 for HDD without encryption kit
              Fy7-0432-000 for HDD with encryption kit
              ans we changed hard disks and conversion boards ASSy for both hard disks and using sst format,
              we formatted hard disks and install the system
              and the result is the same
                • 16083
                Kit (TYPE-C; 2 HDDs
                is your error e602-2002
                Check the connection between the encryption board and HDD, and between the encryption board and the main controller.
                Try to clear the encryption key in the service mode.
                At the service mode level 2; COPIER>FUNCTION>CLEAR>KEY-CLR
                try the format & reload again
