IR 3225N E0003-000
  • mido
    • Nov 2011
    • 176
    IR 3225N E0003-000
    Hi all,
    Please I need your help about this error code E0003-000?????? the error display then the machine turn off automatically.
    what's it mean????
    thanks
  • laitang
    • Nov 2012
    • 627
    Re: IR 3225N E0003-000
    It mean: The fixing temperature is too low after a standby state.
    Replace the main thermistor.
    Replace the DC controller PCB.
    • teckat
      • 16083
      Originally posted by mido
      Hi all,
      what's it mean????
      thanks
      Remove fix unit_check for stuck paper\
      Are u a tech_? if not_ call for service
      U will need to clear error in service mode
      Service Mode level 1 > Copier > Function > Clear > DC-CON
      This is a must below----------
      If possible run a P-PRINT before clearing the DC Controller to re-input the correct values. Copier > Function > MISC-P > P-PRINT
      • mido
        • Nov 2011
        • 176
        Hi,
        Yes I'm a tech. the error cleared by clear error under funtion > clear > error
        thank you
        • teckat
          • 16083
          Hi,
          thank you
          good> now check your outlet for proper voltage & proper ground
          HOT>GROUND
          HOT>NEUTRAL
          NEUTRAL>GROUND= this should be between 0.0v>0.5v
          • ARUN MISHRA
            • 80
            paper stuk in upper fixing roller
            sigpicARUN KUMAR MISHRA
            • jrgf67
              • Feb 2010
              • 37
