canon isensys mf4550d error code e001-0000
  • criz
    • Jul 2025
    i have a multi funtion printer canon mf4550d first trouble is e000-0000 cause of lightning one fuse open after i fix the fuse the error again is e001-0000 but the fixing unit are heat! help me pls
  • laitang
    • Nov 2012
    • 627
    Re: canon isensys mf4550d error code e001-0000
    e001-0000: Abnormal hightemperature detection
    Check:
    - Fixing Assembly.
    - Engine Controller Board.
    • criz
      i check even thermistor and fixing film all are ok.already clear but after reboot same problem.
      • criz
        10708428_851397228228225_478505081_n.jpg fixing connector its is 220volt output or not?
        • zdravko
          • Jun 2013
          • 2
          Do you have a turning silicone roller?
