CLC3200 on Linux Mint. No output at all and no errors
  • AnotherBigAl
    • 34
    I have gone over to a totally Linux Mint (Ubuntu derivative) office and have installed the latest Canon software to run my CLC3200. File name "g1483en_lindeb32_0207.deb". No problems with the installation which installs a queue called CQue which in turn works via the CUPS (Common Unix Printing System) server. I easily set up the appropriate queue. However, when I sent a couple of test pages there was no output what so ever. Looking at my log file I see the following:
    "POST /printers/CLC3200 HTTP/1.1" 200 280 Create-Job successful-ok
    "POST /printers/CLC3200 HTTP/1.1" 200 2478 Send-Document successful-ok
    "POST /printers/CLC3200 HTTP/1.1" 200 219 Create-Job successful-ok
    "POST /printers/CLC3200 HTTP/1.1" 200 38325 Send-Document successful-ok
    so no help there.
    so no help there.
    I am flummoxed and have absolutely no idea where to look next so this is a plea for help. Has anyone got any suggestions please?
  • teckat
    • 16083
    Re: CLC3200 on Linux Mint. No output at all and no errors
    What Print options are installed on 3200 _?
    Canon Print Kit_?/ Canon Print Controller_?
    • AnotherBigAl
      • 34
      Hello teckat,
      Thank you for looking at my problem. I think I need to explain a little more. Firstly I am not a technician. I work in Pembrokeshire, the very far West of South Wales. All Canon techs are apparently in England and I simply cannot afford the mileage charges for a 400 mile round trip. Local dealers are all either Samsung or Toshiba and do not deal with Canon machines.
      Our printer has worked well over the last 10+ years, serving a small network of Windows XP machines. It has a Saddle finisher N2 and twin paper deck (I believe it is called a Cassette Feeding Unit X1) installed and has a fixed IP address. Nothing on the printer was changed when I installed the software on the Linux machine.
      I downloaded the appropriate 32 bit installation file, g1483en_lindeb32_0207.deb, from the Canon driver website and ran sudo dpkg g1483en_lindeb32_0207.deb to install the driver. Once installed, I set up one print queue. I can send documents to the queue without any problem but there is no output what so ever. The printer is obviously not receiving any document information as the data light does not flash.
      I am still at the beginning of the Linux learning curve but am pretty sure that my problem is within the software on the machine rather than the printer.
      What Print options are installed on 3200 _? I think/hope I have answered that above.
      Canon Print Kit_?/ Canon Print Controller_? I am not sure what you mean by print kit but on Windows it was using the Fiery controller.
      • teckat
        • 16083
        OK !
        so u have a C1 Fiery controller box on back of printer.
        & printer was used in past with a Windows environment \ that was networked.
        • AnotherBigAl
          • 34
          • teckat
            • 16083
            have u checked the Linux Mint Forum ??
            Linux Mint Forums
            • AnotherBigAl
              • 34
              It is difficult to know where to go.. At the moment the only post I have made is here as I reasoned, well I did at first, that it was a print problem. On thinking about it I suspect you are right. I'll try over there and see what they say.
              • teckat
                • 16083
                print out a Configuration page from control panel (PRINTER TAB)/
                what ver.? is that C1 Print controller ???
                is this the box on back of your printer
                You can print to the Printer Unit-C1 directly from UNIX workstations
                TO PRINT FROM UNIX
                โ€ข On a system running a BSD-based variant, use the lpr command to send a job to the
                Printer Unit-C1, as follows:
                lpr <-Pprinter> <-#copies> <filename>
                For example, if the Print queue of your Printer Unit-C1 is named print_Server, your
                file is named Sample, and you want to print two copies, type:
                lpr -Pprint_Server -#2 Sample
                โ€ข On a system running Solaris 9 or any System V implementation of UNIX, use the
                lp command to send a job to the Printer Unit-C1, as follows:
                lp -d <printername> -n <copies> <filename>
                lp -d print_Server -n 2 Sample
                Is this the driver location used ??
                CLC3200/3220-C1 v2
                  See if your printer is recognised by the computer,
                  Use the lpstat(1) command to see a list of available printers:
                  lpstat -p -d
                  Try the Ubuntu forums, blag it, tell them you are using whatever version of Ubuntu. I say this because Ubuntu seems to be the most popular Linux distro. Whatever works on Ubuntu should work on Mint since they are both .deb based.
                  • AnotherBigAl
                    • 34
                    Hi teckat,
                    From the configuration page I am told that:
                    Memory = 128 MB
                    Software = EFI Fiery System 5.1e
                    Disk size = (MB) 17092
                    Disk free space (MB) = 15704
                    I note that although the fixed IP and netmask are correct, 192.168.0.4 : 255.255.255.0 the gateway address is the same as the fixed IP. Probably a red herring as it has worked like that for many years. I do not intend to change it.
                    At the end of the print out I am shown the BIOS Setup
                    BIOS version = 4.02 04/11/02
                    Diablo version:
                    Base = 3_0-12_Sep_2002
                    diablo = 2.4-12_Sep_2002
                    fdisk = EXT2-IDE-RO_Jan_2003
                    kernel = 2.4-10_30_2002
                    platform = MXi12_Sep_2002
                    Yes, the picture does show the box on the back of the printer
                    I am not sure what variant Linux Mint is,(Ubuntu) so I tried both commands. The print queue is called CLC3200 so I used that as the printer name. I created a special text file in my home directory. Just a few lines and txt as as opposed to a Libre Office writer document.
                    $ lpr -Pprint_CLC3200 -#2 sample.txt. Output = lpr: The printer or class does not exist.
                    $ lp -d print_CLC3200 -n 2 sample.txt. Output = lp: The printer or class does not exist.
                    I deduce from that that the printer queue is not installed correctly.
                    Thank you for joining in skynet. I tried
                    $ lpstat -p -d. Output = printer CLC3200 disabled since Tue 16 Sep 2014 16:21:06 BST -
                    The printer configuration is incorrect or the printer no longer exists.
                    It seems to me that something pretty major is wrong with my setup so I have decided to go for a complete re installation of the operating system. I have some data to move off of the machine first but also I have got a busy weekend away from the office so I don't expect to have completed it before Monday next week. Once done I will re run the commands and report back.
                    I will also ask on the Mnnt and Ubuntu forums next week if there are still problems after the re install.
                    I am very grateful for your help and please don't think that I have forgotten all about this as seems to happen in so may threads on forums that are left with inconclusive endings.
                    • alex@wocltd.com
                      • 430
                      how come your using linux mint? - would suggest you use an ubuntu version as printing has pretty much been sorted on this platform - you should be able to use the generic postscript driver as a workaround (system setting-printers-add printer),hope this helps
                      • AnotherBigAl
                        • 34
                        When the support for XP finished I looked around to see what else was available. I have tried various Linux versions in the past, more or less always dual boot although I have once set up a triple boot. When I asked around the consensus was that Mint was the most user friendly of all the Linux operating systems. I now have 7 machines on my LAN running Mint so it is too late to change. Anyway, as it is a derivative of Ubuntu /Debian apart from the different philosophies and the various kernels there is not a lot of difference; isn't there? Most of the installations use LVM and that was the only fiddle as Mint only supports a very crude version of that. Each machine uses 5 logical volumes and that took some time to get set up. I really would not want to go back and do all of that again.
                        • alex@wocltd.com
                          • 430
                          okay - that answers that then,I got my teeth into mint some years back so dont know now what its repository for support for printers are like - however give it go add it by the ip address and see (if listed) 3200ps or equivalent....or do you have a generic ps listed?
                          • AnotherBigAl
                            • 34
                            • alex@wocltd.com
                              • 430
                              er, yup i know what the 32xx(an antique) is as I'm a canon dealer.......just checked on Trusty tahr(Ubuntu Studio 14.04) running as vmware indeed in the repository of added printers you already have 2620 ps & pcl fotomatic drivers which will work - tested on irc3580 using 3170 driver and Ira5030 using generic driver ......can you provide a list of printers listed within the mint repository?
