E000355-001
  • Age102
    • Sep 2014
    • 8
    E000355-001
    Hi Folks
    Just fitted main controller taken off IRC2380i in working order fitted to IRC3080i part numbers are the same Machine is booting up now although slowly then errors E000355-001.
    Does anybody know if you have to swap any original pcb's ie memory pcb ect onto the replacment Main controller.
    Any help would be good.
    • 16083
    Re: E000355-001
    Originally posted by Age102
    Hi Folks
    If you remove the Main Controller PCB for repair by an Authorized Parts Repair Facility (A.P.R.F.),
    ensure
    the Counter Memory PCB has been removed and remains with the engine
    E355=
    Mismatch of serial numbers of three items: ECO ID PCB, Main Controller PCB (SRAM) and Counter Memory PCB.
    Press Additional Functions button then #2&8 together> then Additional Functions button
    then again>Additional Functions button then 1&9 together> then #3 (brings u into LEVEL3)
    COPIER>FUNCTION>CLEAR>E355-CLR
    Turn OFF and then ON the equipment.
    The Counter Memory PCB, ECO ID PCB and SRAM PCB retain information pertinent to the specific engine they are installed in.
    SRAM is mounted onto the Main Controller PCB. in this Series
    Ensure that you never swap any of these circuit boards with another engine.
    If any of these circuit boards are swapped, it can result negatively in equipment performance.
    E245, E246, E247, E354 and E355
    DO NOT CHANGE TWO OR MORE BOARDS AT ANY ONE TIME. THIS CAN RESULT IN THE EQUIPMENT ENTERING AN ERROR CODE LOOP. ONCE THIS OCCURS, YOU MUST CONTACT THE CANON TECHNICAL SUPPORT CENTER FOR ASSISTANCE.
    • Age102
      • Sep 2014
      • 8
      Re: E000355-001
      Thanks for your help and info, all working.
        • 16083
        Re: E000355-001
        Good! - what was your final find_?
