IR 5075 - Print wirelessly
  • zelotprotos
    • Apr 2014
    • 36
    [Misc] IR 5075 - Print wirelessly
    Dear Friends.....
    Is it possible to print by wireless connection (WIFI) on Canon IR 5075?
    Is there any add-ons for IR5075 which can make it possible to do?
    • 16083
    Re: IR 5075 - Print wirelessly
    Originally posted by zelotprotos
    Dear Friends.....
    U NEED> Wireless Interface Board NB-W1.
    Below is a chart outlining the specifications for the wireless network board NB-W1 including some of the more common features such as security, speed, and transmission modes.
    Voice Guidance Kit B1 cannot be used at the same time.
      • 16083
      Follow the procedure described below to initialize the setting of wireless card and resume the factory settings:
      Additional Functions > System Settings > Extension Card Settings > Wireless LAN Card Management >Initialize Settings Values > select Initialize (WLAN Off)
      Turning off/on the main power of the host machine enables the setting change.
      • zelotprotos
        • Apr 2014
        • 36
        Thank you.
        Right now, I don't have that "Extension Card Setting" option on the "Additional Functions - System Settings".
        so the new option (Extension Card Setting) will be appear automatically when I add that Wireless Card ?
          • 16083
          Thank you.
          Yes
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            If cost is an issue, you may prefer a wireless bridge, or even a wireless range extender with one or more Ethernet ports on it.
            Should be $75 at max, most likely much less.
            The only disadvantage is that it is an external piece of hardware, along with a power adapter that will require an AC outlet.
            I have a range range extender at home, and my Brother laser printer is plugged into a network port on it. Works great, and I still get full web page functionality on the printer.
