Irc3220 toner fixing problem
  • cesarkazu
    • Jun 2012
    • 28
    Hi, Please
    I have a problem in Irc3220, only appears in a A3 paper size only and weight 90 g/m, view attachment arquive, i "Turn the adjusting screw [1] at the
    front/rear so that the length of the pressure" and did not effect, fusing roller upper, lower and bearings is changing.
  • mramlawi
    • Jul 2011
    • 838
    Re: Irc3220 toner fixing problem
    Originally posted by cesarkazu
    [ATTACH=CONFIG]26493[/ATTACH][ATTACH=CONFIG]26494[/ATTACH]
    Hi, Please
    I have a problem in Irc3220, only appears in a A3 paper 90 g/m, view attachment arquive, i "Turn the adjusting screw [1] at the
    hi ,
    did you checked the ITB if theres a spots on it cos looks like ITB problem
    Distinguished road makes you jewel in rough
    • cesarkazu
      • Jun 2012
      • 28
      Originally posted by mramlawi
      hi ,
      yes, i check the ITB, seemed like everything was normal, this defect appears in A3 paper size only.
      • teckat
        • 16083
        Hi, Please
        COPIER>FUNCTION>FIXING>NIPCHK
        • cesarkazu
          • Jun 2012
          • 28
          Sorry, i am beginner
          nip.jpghow to measure it?
          • teckat
            • 16083
            [ATTACH=CONFIG]26498[/ATTACH]how to measure it?
            see attach/ u need to slide out sorter & cheat it's switch to run nip check
            • cesarkazu
              • Jun 2012
              • 28
              already do this, the problem is that the image is not in the center like figure F06-402-02
              • teckat
                • 16083
                That is only an example
                U are only going to measure the crossover shiny patch) (front to back of test print)
                If patch is to wide on ends-u get poor fixing on ends.
                • MunsterTech
                  • Sep 2014
                  • 377
                  it looks as if you are doing 100 % coverage on 90gsm? Try doing the same from the bypass using 100gsm or heavier and setting to heavy 1, this slows the fixing down to fuse into the media properly.
                  • teckat
                    • 16083
                    Good point on heavy stock,
                    But u can not run full bleed 100% coverage on this model with any success, with these crap fix units
                    • cesarkazu
                      • Jun 2012
                      • 28
                      is it only occurs when at 100% coverage, 75g 90g or heavy paper in the tray or manual, I suspect the upper roll, when you get a new one, will post resolved
                      • teckat
                        • 16083
                        this model is not a Printing Press /
                        do u understand your/or customer cost expense when u attempt to print at 100% toner coverage ?
                        TONER USAGE
                        DRUM LIFE
                        FUSER LIFE
                        • hinbox
                          • Jul 2014
                          • 22
                          pull out you itb cleaner blade and check for buildup of waste toner also problem could be in the itb assy and not the belt if not fuser.
