irc 3220 scan swap
  • pontiac
    • 420
    irc 3220 scan swap
    Is it possible to remove the send option from one ir c3220 to another , copier with A2P send kit has frame damage and we would like to transfer scan option, would transferring the complete control pcb assembly with kit to second copier work? Thanks
  • teckat
    • 16083
    Re: irc 3220 scan swap
    NO FOR SEND
    Resolution Switching Board A2 and Color Universal Send Kit A2P are required to give the imageRUNNER C2620 / C3220 Universal Send functionality.
    The imageRUNNER C2620, C3100, C3200, C3220 , C5800, and C6800 models have optional Color Universal Send Kits available for them.
    These Color Universal Send Kits come with a dongle and a CD-ROM.
    The copier must be flashed from a PC (with the dongle connected to the PC's parallel port) using the Universal Send Setup Tool utility included on the CD-ROM in order to install the Universal Send feature.
    Once the Universal Send option is installed on a copier using a Universal Send dongle, the Universal Send dongle becomes 'married' to the machine.
    It can only be used to re-install the Universal Send feature onto the same exact machine.
    The dongle CANNOT be used to install the Universal Send feature onto another copier.
    The Universal Send Kit cannot be transferred from one machine to another. If a dealer wants to install Universal Send onto another Color Enabled imageRUNNER machine, then he or she must purchase another Color Universal Send Kit.
    The Color Universal Send Kits that ship with the Universal Send dongles are not LMS options. There is no LAN number included with the kit. There is no key number to be registered on the machine. These kits CANNOT be transferred.
    YES FOR>SCAN
    The optional Color Network Multi-PDL Printer Kit or imagePASS must be installed to use this function.
    • pontiac
      • 420
      We had to ask. Thanks teckat for reply.
