IR adv 5235i. problems installing postscript license
  • misserable old git
    • Aug 2014
    • 19
    When installing the AR1 postscript license key I get a message saying "insufficient memory to install option".
    I have installed this kit before on 5235's without any issue.
    Any Ideas?
  • candoo
    • Nov 2008
    • 14
    Re: IR adv 5235i. problems installing postscript license
    You will need to install and additional memory to Main Controller 2. EXPAND512MBTypeD is required when using PS Kit
      "Miserable Old Git" is in London and according to the parts list,
      FM0-0322-000 1 MEMORY PCB ASSEMBLY EUR
      This memory is fitted to European models.
      DDR2-SDRAM (M1) 1 GB (standard) / clock frequency: 200MHz
      Rasterizing, rendering, resolution conversion, coding / decoding
      DDR2-SDRAM (M0) 512 MB (standard / Op.*) / clock frequency: 200MHz
      Product name: Additional Memory Type D (512MB)
      To be used when using the following options:
      PS Printer Kit-AR1, Direct Print Kit (for PDF / XPS)-H1, imagePASS-B2,
      ColorPASS-GX400
      DDR2-SDRAM (P) 512 MB (standard) / clock frequency: 200MHz
      Print image processing, delay processing between drums
      * The capacity differs according to the location or model
      I am in the UK also and have never had to fit more memory when installing a PS license or a fiery.
      Check the memory ServiceMode >COPIER>DISPLAY>ACC-STS>RAM it should be 2GB
      Clean and reseat the memory.
        • Aug 2014
        • 19
        hi all... thanks for the input. the device is not showing correct amount of ram, so I will be checking tomorrow for bad seating. MOG
        • candoo
          • Nov 2008
          • 14
          No worries. Good luck with it. In Aus we have to fit an additional memory. Must be something to do with all the sunshine we get here. By the way, how the weather there in good old London town. Was there earlier in the year, weather was great in June.
