CANON IR5075 showing multiple error codes
  • worldviewatl
    • Jun 2025
    [Error Code] CANON IR5075 showing multiple error codes
    hello
    my canon Ir5075 showing different error codes.
    e110-001, e005, e014, e840 etc...
    but sometimes the machine works perfectly.
    machine working with 110volt stepdown transformer.
    But there is no voltage stabilizer.
    Is this voltage problem or something else?
    I am an end user from India. So please advice me for a good stabilizer if it is the problem with voltage
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: CANON IR5075 showing multiple error codes
    It is very rare to find a machine giving multiple errors at the same time and more so when they are not interrelated.
    However since you are an end user to the said machine,i would advise you get a qualified tech to verify these error
    codes since each has adifferent problem and cause.Buying a stabilizer alone may not solve the problem.
    • teckat
      • 16083
      Originally posted by worldviewatl
      hello
      good advice has been given
      u are most likley losing 24v DC during operations to have those sporadic various codes
      possibly a bad Main Controller PCB & or a bad Main DC Power Supply > or a combination of both/
      u can also have a supply voltage issue from power company & or transformer > including a poor Grounding issue from outlet-
      time for a pro to check
