error code e0024-0001 displaying in my ir2870
  • n jagannath rao
    • Aug 2025
    facing problem of paper jam and displaying error code e0024-0001 pls tell me the solution
  • laitang
    • Nov 2012
    • 627
    Re: error code e0024-0001 displaying in my ir2870
    Check developing assembly connector
    • jrgf67
      • Feb 2010
      • 37
      Saludos. Deberias cambiar el revelador
      Greetings. You should change the developer
      • mramlawi
        • Jul 2011
        • 838
        Its the toner sensor located inside the cylander of development unit ,u can clean the cyalnder from the toner and then clean the sensor after that make on the service mode install toner .
        Distinguished road makes you jewel in rough
