please i have this error code e0000805-0015 on my canon imagepress c1. please help me out thanx
canon imagepress c1
Re: canon imagepress c1
E805 = Error in detecting stop of fixing exhaust fan stop or fan fault
Error in left exhaust fan=FM16------# FL2-5436
this is a two-speed fan> half & full > they crap out
0015 The left exhaust fan of fixing assembly is unlocked .
Turn off the main power,
1-check power supply to the fan/or replace fan, and then, turn on the main power.
COPIER>FUNCTION>PART-CHK
Specify a fan to be checked.
(Range: 1 to 30)
1) Select an item.
2) Enter the code of a fan using numeric keys.
16. FM16: Left exhaust fan
left exhaust fan [1] with the duct.
- 1 connector [2]
- 1 screw [3]
Connector No.
Back/Rear driver PCB.
J3803/J3810B
J3803-Rear driver PCB.
PIN 7 =FAN ON
8 = GROUND
9 = Fan Lock
J3810B
PIN 1=LOCK
2= HALF
= FULL
3Last edited by teckat; 09-25-2014, 12:09 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**
