Imagerunner 3245 compatibility
  • copicatt
    • Nov 2008
    • 366
    I am supposed to install an iR3245 that I have into a customers office next week, but just got this email from their IT guy...
    Anybody know what he is meaning? I'm not for sure. Sounds like he is wanting to print using an HPLJ5 Driver???
    Message:
    Let me know and sorry about this.
  • teckat
    • 16083
    Re: Imagerunner 3245 compatibility
    Message:
    he must mean> will iR3245 support the HP's Universal Print Driver (UPD) The UPD, is available in 32 and 64 bit packages, is a single driver that supports PCL5, PCL6, and HP PostScript; Level 2 and 3 emulation.
    don't think it's possible as u can see below
    Canon U.S.A. : Support & Drivers : imageRUNNER 3245
    Printing
    Supported PDL
    imageRUNNER 3245/3235:
    Standard. UFR II,
    OPTIONAL. PCL 5e/6, PS 3 em.
    PCL Printer Kit-AA1=PCL 5e, PCL 6
    PS Printer Kit-AA1
    =PostScript 3 Emulation
    Scan
    Network TWAIN Scan: Standard
    Network Scan Utility: Color Network ScanGear
    Color Universal Send
    is Optional on 3245/3235 models)
    Canon Generic PCL6 Printer Driver v2.00 (32-Bit) simplifies printer support by enabling users to print to various multi-function devices with the same driver.
    • copicatt
      • Nov 2008
      • 366
      They use some program called Streamline? anyway he sent me this from their program provider: He said it was a patch they sent him. The way I read it, if they install the patch in their system, they would be able to print to almost any device as it converts it to pdf......I think.
      PDF Interface Pre-Installation Instructions.pdfPDF Interface Pre-Installation Instructions.pdf
      • yazj
        • Aug 2011
        • 29
        Hi teckat ,
        i have this type of machine iR 3245 but i try to print using UFRII driver is not working as per to the specifiaction stated that having standard PPD of UFRII.
        any advice on this? machine is from europian region.
        Thank you in advance
        Kind regard
        YAZJ
        • teckat
          • 16083
          Originally posted by yazj
          Hi teckat ,
          Kind regard
          YAZJ
          explain
          1-are u connected to a PC or MAC ?
          2-are u connected to a TCP/IP network/ AppleTalk ?
          3-connected via USB ??
          You can confirm what printer driver(s) you can use by following the procedure below.
          1. Press (Counter Check) on the touch panel display.
          2. In the Counter Check screen, press [Device Configuration].
          3. Confirm the printer driver name displayed under [Option].
          Remote UI = can u see your printer > type printers I/P into browser
          Re-Install Driver
          Canon UFR II/ UFRII LT Printer Driver v14.02
          This driver is for 32bit and 64bit Windows OS.
          Version v14.02
          Released on 27-05-2015
          Description:
          This driver uses a Setup program for installation.
          However, you can also use the Add Printer Wizard by specifying the '.inf' file under the 'Driver' folder when selecting the manufacturer and model of your printer.
          Supported OS:
          Windows XP SP3(32/64bit)
          Windows Vista SP2(32/64bit)
          Windows 7 SP1(32/64bit)
          Windows 8 (32/64bit)
          Windows Server 2003 SP2(32/64bit)
          Windows Server 2003 R2 SP2(32/64bit)
          Windows Server 2008 SP2(32/64bit)
          Windows Server 2008 R2 SP1(64bit)
          Windows Server 2012 (64bit)
          Compatibility:
          Operating system(s): Windows 2003, Windows 2008, Windows 7, Windows 8, Windows Vista, Windows XP
          Language(s): English
          Interface PDL: UFR
          Downloads
          Below are the available downloads. Depending on the file, you may be asked to enter the serial number of the product. Please have it ready for your convenience.
          Software File size
          o155j88en_w_UFRIIv1402_32_64.exe 28615.7 Kb.
