Canon 3180ci thin black line?
  • steve1973
    • Sep 2013
    • 43
    Any advise would be appreciated my canon 3180 has started producing a thin black line on all output? it always appears on the reverse side - only recent change was a black replacement toner (genuine canon) machine is probably due an ITB cleaning unit but would this cause a black line on reverse side? drum is recent change only 6% used,black dev unit is on 13% - the line does sometimes appears in different places on the page - but is always on the back of copies.
  • teckat
    • 16083
    Re: Canon 3180ci thin black line?
    Does this line move ?
    Is in paper feed direction <-----> right>left< / check Fix Unit
    or cross feed = front to back
    • steve1973
      • Sep 2013
      • 43
      It looks to be paper feed direction right - left, and the line does move,when doing a couple of copies the line moves approximately 35mm on the second copy.
      • steve1973
        • Sep 2013
        • 43
        This machine is now producing the error code E000020-0493 sometimes on startup and every time when attempting an internal clean.
