jam in canon IR3530
  • adel_nathan
    • Jul 2011
    • 103
    [Jamming] jam in canon IR3530
    hi
    i have this same problem in a 3 photocopy machine
    the problem is >>>> the paper " size A4 " jammed just edge reach vertical path roller
    give jam code " FF02 " !!!!! and no paper complete to the end
    when i change to size A4r it can pass one or two and others jammed
    i try using multifeed try it's working good " no paper jammed "
    changing or cleaning feed and separation roller not help " i try it several times "
    this problem happened some times when using cassette no. 1 and in other machine cassette no. 2
    please help
    am waiting ur advise
    thanks
    Re: jam in canon IR3530
    If you put pressure on the lower right door and then copy does it jam?
    Have the door modifications been done?
    FM3-1296 Right Lower Door assembly
    FM3-1297 Right Inner Door assembly
    Are the vertical path rollers black in colour?
    The grey ones work better
    FB6-4852-000 ROLLER, VERTICAL PATH
    Are the registration and pre registration sensors worn?
    Newer ones have a metal edge to help with wear.
    • adel_nathan
      • Jul 2011
      • 103
      FM3-1297 Right Inner Door assembly>
      first thanks for response
      the right lower door modified
      [/QUOTE] Are the vertical path rollers black in colour?
      The grey ones work better [/QUOTE]
      it's grey one
      [/QUOTE] Are the registration and pre registration sensors worn?
      Newer ones have a metal edge to help with wear.[/QUOTE]
      i don't under stand this point >>> please explain
        This sensor is above the grey roller on the pickup assembly is it worn? you could put an extra wrap on the spring
        • adel_nathan
          • Jul 2011
          • 103
          ok boss i will check and replay tomorrow
          thanks a lot
          • canonbundy
            • Jun 2012
            • 607
            hi
            please help
            thanks
            Replace P/up, Feed & Sep Rollers , Clean T/sport Rollers, remove small black Rubber Flapper Buffers in R/H door (if tacky), replace foam rubber strip on Lower Door, if Reg/Prereg plastic Sensor Flag is worn - cut a piece of Mylar to shape of Flag & fix with double sided tape.
