IR 6000 FIXING TEMP
  • ARUN MISHRA
    • 80
    [Misc] IR 6000 FIXING TEMP
    Anyone please help ...........how can low the fixing temperature control ....the room size is very short.....and no a/c ....only fan ....sometime work i feel heating problem in the machine ....heat spread into drum unit and JAM the cleaning unit .....i replace the fixing upper black duct cover ...so please give me some order for lowering the fixing temperature ....thanks a lot ..........
    sigpicARUN KUMAR MISHRA
  • ARUN MISHRA
    • 80
    Re: IR 6000 FIXING TEMP
    how i control fixing temp lower than stranded....
    • tomcatt
      • Jul 2010
      • 92
      Check your duct work for the exhaust fan to the left of the drum unit. It will get cracks and fall apart and not provide sufficient cooling for process unit
      • ARUN MISHRA
        • 80
        change new duct cover .......and in option /body/fix-temp/2 ............so i report after some days ...........thank a lot
