iR5055 Fuser
  • imagewalker
    • Jun 2010
    • 94
    [Misc] iR5055 Fuser
    Canon imageRunner 5055
    Is there a way to stop or slow the fuser running in standby or
    when the machine is not in use. Can't find it in the manual...
    Damn fuser just keeps spinning EVERY 30 SECONDS...WTF!!
    Never notice that till today.
    Now i know why my lower fuser roller bearing keep burning out.
    Yeah, tried to look at older posts but no luck with this sites search ...
    Gives you anything with the letter A or E ......
    iw
  • wassem
    • Aug 2012
    • 166
    Re: iR5055 Fuser
    iw
    i think your machine requires toner
    • laitang
      • Nov 2012
      • 627
      Re: iR5055 Fuser
      COPIER > OPTION > BODY > IDL-MODE
      Use it to select idle rotation mode for the developing assembly.
      0: fix to low humidity mode (off)
      1: environment control (default)
      2: fix to normal temperature/humidity mode (idle rotation for 120 sec) (default)
      3: fix to high humidity mode (idle rotation for 300 sec)
      4: power save mode
      • spectraindo
        • May 2008
        • 313
        Re: iR5055 Fuser
        You can adjust the Timer at which the machine goes to sleep mode.
        Hit Additional Functions > Timer Settings > Auto Sleep Time > 10 ~ 15 minutes is OK.
        In Sleep Mode the Fuser does not rotate.
        • imagewalker
          • Jun 2010
          • 94
          Re: iR5055 Fuser
          Thanks for the suggestions guys will try all of this out.
          • COPIERTEC ASSOCIATES
            • Aug 2011
            • 279
            Re: iR5055 Fuser
            iw
            This machine is designed in the fuser by use of a sunchronising motor,which is supposed to run at given intervals by default.Therefore,there is no way that you can either stop or slow down the running of the fuser.As for the lower fuser bearing,it is a common occurance that i have personally experienced on the
            following models;IR5570,5055,5070,6570 as these machines use the same fuser unit.We could possibly refer this problem to the manufacturer,coz the older versions IR5000 to 6000 do not have this problem.
            • spectraindo
              • May 2008
              • 313
              Re: iR5055 Fuser
              The fixing heater of the iR5570/6570/5055/5075 works by heating only a small portion of the fuser roller by induction heating.
              Therefore the fuser roller must be rotated at the time the induction heater goes on so that the whole surface of the fuser roller is heated.
              To minimize the rotation is to put the machine into SLEEP MODE, when the induction heating is of, the fuser roller stops rotating.
              • imagewalker
                • Jun 2010
                • 94
                Re: iR5055 Fuser
                Im still playing around with this problem. Have 3 customers where Ive never had lower fuser problems for 2 years and i have 2 that i have to replace lower fusers rollers and bearings every six months.
                FML
                Thanks for the help ..keep you posted.!
                • vigour
                  • Aug 2010
                  • 1038
                  Re: iR5055 Fuser
                  What bearings are you using?
                  The latest OEM roller now comes with bearings attached at the factory.
                  They last a whole lot longer than before
