Ir7105 V1 Finisher Jamming
  • sunboi
    • Dec 2011
    • 34
    Hi Guys,
    I would need some expert help over here.
    I am experiencing paper jam on V1 Finisher.
    The jam code reads
    1004 Shift unit sensor delay PS4 The shift unit sensor (PS4) does not detect paper within a specific period of time (distance) after the inlet sensor (PS3) has detected paper
    May I know what is the course of action to take? I am really stress up with this consistent jamming.
    Thanks in advanced!
  • teckat
    • 16083
    Re: Ir7105 V1 Finisher Jamming
    Originally posted by sunboi
    Hi Guys,
    The jam code reads
    Thanks in advanced!
    is the the lead edge of the paper dented.
    is this on all paper sizes
    is a Internal Punch Unit V1 installed. if so>paper may wear cuts into the mylar
    check if the Loop Sheet (mylar) has any cuts or damage =Loop Sheet is FC6-6209-000
    • Rachid.Akli
      • Oct 2011
      • 595
      Hello,
      1004 is delay Jam. I attach the finisher sensor positions. Ask yourself the following questions and try to answer them:
      1- Are the paper feeding rollers between S3 and S4 rotating?
      2- What is the paper position when it jams?
      3- What is the paper shape ? Is there any mark on it?
      4- Is the sensor S4 good ?
      Sensors in Saddle_Finisher_V2.pdf
      Rachid
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • irwin_albillo
        • Oct 2015
        • 7
        I'm having the same problem. Jamming from every tray on 11x17 every time. Stops right before PS4. Anyone have advice?
        • teckat
          • 16083
          So u have a delay jam.
          What happens when you remove the sorter.
          _?
          • irwin_albillo
            • Oct 2015
            • 7
            Removed V1 finisher, runs perfect! Rebuilt fuser unit a month ago. Replaced all rollers on trays. The finisher does have a 3 hole punch unit. Paper stops after reaching shift unit. Thanks for your quick reply!!
            • irwin_albillo
              • Oct 2015
              • 7
              Anybody there???
              • johnservis
                I have the same issue with the 11x17. It stops in the shift unit every time. I get 1004. Also when duplexing it stops in the duplexer every time . I get 0111. The sheet doesn't make it all the way down the chute before it tries to reverse and jams. It runs 8.5x11 all day long. I cannot figure this out.
