sst firmware canon ir c 2220
  • falah taan
    • Feb 2013
    • 67
    hlo evryone pleas i need sst firmware of canon ir c 2220 any one can hepe me
    fa64lah@yahoo.com
  • ernesto
    • Oct 2011
    • 430
    Re: sst firmware canon ir c 2220
    fa64lah@yahoo.com
    HI,
    if you set up gateway and dns address then you ll be able to update directly from the machine on internet.
    1). Press [Setting/Registration (User Mode)] button on the control panel.
    2). Press [2] and [8] buttons at a time on the control panel.
    3). Press [Setting/Registration (User Mode)] button on the control panel.
    4). [Service Mode] screen is shown.
    5). Press updater
    and so on ........
    • teckat
      • 16083
      All imageRUNNER ADVANCE Series
      Three Methods of using the CDS [Content Delivery System] to Update Firmware Defined.
      Method 1:
      The technician is onsite, enters service mode on the copier, selects the updater and has the machine attach to the CDS where the firmware is brought to the machine and the technician may select a version to apply and manually install the firmware.
      Method 2 :
      The Dealer uses imageWARE Remote to connect to the device and schedule a time where the device will connect to the CDS to obtain Firmware. The Firmware will reside on the device until such time as a service technician visits the device and manually applies the Firmware.
      Method 3:
      The Dealer uses imageWARE Remote to connect to the device and schedule a time where the device will connect with CDS, obtain the firmware and apply it automatically without any intervention of a technician.
      • MunsterTech
        • Sep 2014
        • 381
        alot of larger corps will have firewalls blocking the installation, so only way around it is to use the SST
