Canon iR5075 E808-0003
  • emirsarajevo
    • Jun 2025
    [Error Code] Canon iR5075 E808-0003
    Dear,
    My copier is displaying this error (E808-0003) usually after 50 copies. I have searched the forum, but I couldn't find this problem occurring to somebody else. All error code lists contain E808-0001 and E808-0002, without this one occurring on my copier. Does anybody here have experience with this error and can anybody give me an advice to solve it?
    Thank you.
  • teckat
    • 16083
    Re: Canon iR5075 E808-0003
    I would check wall voltage supply ,especially proper ground-from Neutral to Ground =0v>0.5v max.
    Poor ground effects Fix Temp .
    • fr2au
      • Jan 2008
      • 20
      Error Code E808-0002 iR6570 Series & iR5075 Series
      Article Content:
      Symptom
      The Error Code E808-0002 intermittently is occurring.
      Cause
      The outlet that the machine was plugged into measured 67 VAC between ground and neutral.
      Action
      Temporarily moved machine to a correctly configured 240 VAC wall outlet. The outlet problem was corrected by an electrician and the error stopped occurring.
      • teckat
        • 16083
        Article Content:
        Symptom
        Cause
        Action
        THANKS, DID U SEE ABOVE
