iR C1028iF forced download
  • AndyCan
    • Oct 2013
    • 13
    [Misc] iR C1028iF forced download
    I have a machine that is hanging on start up. Is there a way to force it into download mode?
    I have tried holding down 2+8 on startup to no avail.
    Any help will be greatly appreciated
  • Dutchman
    • Jan 2011
    • 58
    Re: iR C1028iF forced download
    You will have to do it in service mode. Main menu 2 then 8 and main menu again. Then you have to enter the password that is the same ira 7654321, once in service mode you should be able to get to the download mode.
    Hope this will help
    • AndyCan
      • Oct 2013
      • 13
      Hope this will help
      The problem is that the copier does not boot to a point where one can enter service mode. The Canon logo appears and the progress bar gets to a third and there it sits. I have been told there is a button or button combination that you can hold down to get into safe mode (like holding 2 + 8 while booting an iRC2380), but I'm buggered if I can find it. I've searched the Service Manual and the bulletins on SIMS.
        Have you tried starting it up with the front door open so the machine doesn't go through its warm up rotation?
        • AndyCan
          • Oct 2013
          • 13
          Yup. No go. It's either a firmware problem or memory or mainboard. But here in South Africa boards are not cheap so I have to do some due diligence before throwing money around.
          • Dutchman
            • Jan 2011
            • 58
            Hi Andycan,
            Boot up laptop or pc with usb cable connected to machine, then power machine on holding down #2 and hold down until it shows usb download available.
            Good luck
            • teckat
              • 16083
              get into download mode when service mode is unavailable*****
              1) Power on the laptop and connect to the machine via a USB cable.
              2) Hold dow the #2 key and turn on the machine.
              3) Keep holding the #2 key down until the "USB DOWNLOAD AVAILABLE" message is displayed.
              Note: The machine will cycle, the progress bar sceen will come on and go off. Keep holding the #2 key until the download message is on the screen.
              4) Now you can start downloading the SSW.
              -------!!!!!!!! to get the Download Mode !!!!!!!
              There are two methods of getting the device into Download Mode.
              Method One:
              Press down and hold the number 2 button on the operation panel, then turn on the Main Power switch of the device, while holding down the number 2 button.
              Keep the number 2 button pressed down until the device boots up, and the following display appears:
              Network Download Available
              IP Address: xxx.xxx.xxx.xxx
              The IP Address line, will display the current IP Address configured on the device.
              Method Two:
              Press MAIN MENU button
              Press the number 2 button
              Press the number 8 button
              Select COPIER
              Press OK button
              Select FUNCTION
              Press OK button
              Select SYSTEM
              Press OK button
              Select DOWNLOAD MODE
              Press OK button
              note:
              The device will go into a booting sequence, and after a few moments the device will display the following:
              The IP Address line, will display the current IP Address configured on the device. That will be the IP Address that is to be used to flash the device from the computer.
              • AndyCan
                • Oct 2013
                • 13
                Method One:
                Method Two:
                Select COPIER
                Press OK button
                Select FUNCTION
                Press OK button
                Select SYSTEM
                Press OK button
                Press OK button
                note:
                Thanks for all the advice guys. As I said, we can't get to service mode as the boot process doesn't start. I suspect the mainboard is kaput. We are going to try swapping out boards with a working machine. I'll post the results.
                • teckat
                  • 16083
                  So u tried the USB cable procedure _?
                  • AndyCan
                    • Oct 2013
                    • 13
                    Yup. NG.
