Black print only In IPR c7010vp
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 170
    [Misc] Black print only In IPR c7010vp
    As in service manual to print in black mode only we have to set in Service Mode---Level 2---COPIER--- OPTION---BODY
    DEV-SP1 0 0 0 0 0 0 0
    bit 7 to 1
    DEV-SP1 0 0 0 0 0 0 1
    we done but also print coming out in color mode
    Note: MN CONT v92.01
    With my greetings.
  • teckat
    • 16083
    Re: Black print only In IPR c7010vp
    bit 7 to 1
    With my greetings.
    Wrong bit READ :-[
    Read from right to left.
    Black Only Mode :-))
    To configure the Canon device to use print Black Only Mode perform the following steps:
    Enter service mode (level 2)
    select COPIER
    select OPTION
    select BODY
    select DEV-SP1
    configure Bit 0 to a value of "1"
    select OK
    press RESET to exit service mode
    The Black Only Mode feature is only effective with those jobs that are pure Black; if any color other than Black is sent, the machine will switch to Color Mode and may experience a production lapse of up three minutes.
    Once the Black Only Mode feature is enabled, print a pure Black job following the procedure in the “Printing with Black Only Mode” and ensure that only the Black Developing Assembly rotates.
    Printing with Black Only Mode.pdf
