iR Adv C5240
  • Zoren
    Technicien de copieur
    • 99
    iR Adv C5240
    Anyone encountered problem like this Cyan Erratic Lines Photo by Renzo_Lorenzo | Photobucket
    during normal copying an erratic horizontal lines appears on it
    Just came out from hybernation.....
    • 16083
    Re: iR Adv C5240
    Glass copies_?
    What about Prints _?
    • Zoren
      • 99
      Re: iR Adv C5240
      Originally posted by teckat
      Glass copies_?
      Both.
      even you make a copy from your saved files in your inbox the copy is the same with streaks of cyan lines. the problem only appears during colored copies otherwise b/w is ok.
      m out of town so haven't check the machine yet
      here's another sample of A4 copy IMG_0940_zps1d80fe8c.jpg Photo by Renzo_Lorenzo | Photobucket
        • 16083
        Re: iR Adv C5240
        Both.
        CYAN lines
        are in Main Scan direction ??? (front of printer to back)/= Vertical Scanning Synchronous Control-----
        if so I would check Laser /Connection Cable/
        • Rachid.Akli
          • Oct 2011
          • 595
          Re: iR Adv C5240
          Hello,
          In this series, the color drums are the same. So, you can swap the cyan drum with the Magenta or the yellow drum.
          Rachid.
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
