iR5055 Second side lead edge, Light copy.
I jammed the machine, found a sheet in the duplex tray 2.
It had two "2 Inch" dents in the paper about "1 inch" from the lead edge of the copy.
I seen this before in the iR5070 and it was the exit one way bearing with gear.
and remember there was something else but i've forgotten its been so long....
One way bearing i cleaned and tested doesn't seem to be the problem, looks like new. No wear on the exit shaft either. The white lever on the exit jam release cover (always cracks) that works the guide into tray 2 is fine as well.
Any other ideas
Hope that all makes sense, my ingrish no good today...lol
Thanks in advance
IW
Any other ideas
Thanks in advance
IW
