Canon ira6055/75
  • mramlawi
    • Jul 2011
    • 838
    Canon ira6055/75
    Dear all ,
    i just to take some feed back about this series of machines IRA6055/75 is theres any disadvantage befor i buy some? thank you
    Distinguished road makes you jewel in rough
    • 16083
    Re: Canon ira6055/75
    Originally posted by mramlawi
    Dear all ,
    • Eddie
      • Jun 2009
      • 31
      i found all canon advanced series to be great....b&w and colour.
      i have a few of the ira6075 in law offices...besides print shops law offices are high maintence clients but since we moves from minoltas to canon.
      very few calls.
      the ir adv6075 does have a wierd fixing assembly setup, but if you fallow the service manual for repairs..all ok
      just watch out for the ir adv c5000 series..e075 errors. but once you get that fixed..all ok.
      cheers
      • onlyinnewfoundland
        • Apr 2013
        • 235
        I have found that all of Canon's B&W Advance series to be pretty awesome overall.
        Fixing assembly in the 6000/8000 was a pain when it first came out, had some issues, but that seems to be mostly resolved now!
          • 16083
          Have u applied any of the 50\60 tech pub fixes needed I listed_ ?
            • Apr 2013
            • 235
            Only things I regularly encounter are the fuser issues.
            A few of those toner bottle issues and I have a waste toner pipe issues as well on one or two.
            Otherwise they are pretty well problem free. They are in relatively low volume areas though!
            • MFPTech
              • 486
              very few calls.
              cheers
              Struggling with one since day one even after the recommended updates.
              The Paper Deck causes intermittent 0105 jams and the Finisher has intermittent punching issues (updated the cover).
              • vigour
                • Aug 2010
                • 1038
                Pickup jamming from deck only --Install modified pre-reg roller or assembly
                For intermittent- erratic punching, I have had to replace 2 punch units to fix it, after trying motors, sensors and controllers.
                • MFPTech
                  • 486
                  Thanks for your help. There is an update for the Finisher [mount puncher*1x FM1-D540-000] Haven't seen an update for pre-reg rollers though, any PN handy please
                  • vigour
                    • Aug 2010
                    • 1038
                    I searched for the info before posting but could not find it. I am sure the pre-reg roller is just a suffix change -010 or 020.
                    I had the punch issues long before they released the info about changing the covers.
                    The two I fixed still have the original covers
                    also
                    For 0104/0105/0208/0209
                    There is a new sensor holder FL3-9005 below the multi paper pickup assy.
                    Old sensor allows nicks in the plastic
                    also
                    A damaged reg assembly causes 0105
                    You may see a couple bent pieces in the front and a white plastic tab out of place.
                    FM4-5156-020 modified reg assy.
                    Take your pre-reg assembly out , You may find some scraps of paper stuck in the metal guide, causing paper to hit it intermittently and cause a jam.
                    • MFPTech
                      • 486
                      Replaced the pre-reg assy - didn't solve the issue - 0105 from PD-A1 has been an issue since day 1. Machine works fine from Trays ... It looks like the PD is too low .... Btw, the punch update made things way worse and had to put the original one back.
                      • vigour
                        • Aug 2010
                        • 1038
                        Try the other 2 solutions, they are officially provided for 0105.
                        I do not remember the code for pre-reg jamming but your description sounded like it fit.
                        I have had to change rollers and clutches on nearly new (advance) paper decks
                        • spectraindo
                          • May 2008
                          • 313
                          Hi TECKAT, can you send me the 50\60 Canon tech pub ? I have some problems with IRA8105.
                          My email address is mulyadikj@gmail.com
                          Thanks a lot.
                            • 16083
                            Thanks a lot.
                            What are the issues ?
                            • spectraindo
                              • May 2008
                              • 313
                              We have these problems :
                              1. ETB Displacement.
                              2. Jam 0112 and 0113
                              3. Error E017-003, M19 seems not working sometimes.
                              4. Error E001 when using Folio or Legal paper.
