service mode advance 9200 series
  • roho
    • Mar 2009
    • 844
    [Misc] service mode advance 9200 series
    I saw there is a service mode setting copier>option>dsply-sw>t-lw-lvl for adjusting a warning for low toner. I went to one of these models, and that service mode isn't there, level 1 or level2. How can this be adjusted without this mode? I have noticdd the 5000 series advanced has this, however it was a 9200 series manula that I found it listed in. Any suggestions or work around? A couple of customers want earlier notification of low toner status. Thanks!
  • teckat
    • 16083
    Re: service mode advance 9200 series
    You can set the machine to display a message indicating that the remaining toner is low.
    This message is useful because it gives a user plenty of time to check their toner stock, and ensure the availability of replacement toner.
    For imageRUNNER ADVANCE
    1) Select Settings/Registration on the copier's display.
    2) Select [Login].
    3) Enter the System Manager's ID as well as the System Pin.
    4) Select [Preferences].
    5) Select [Display Settings].
    6) Select [Display Remaining Toner Error Message].
    4) Select [On] or [Off].
    5) Press [OK].
    or
    it's there
    COPIER > OPTION > DSPLY-SW
    TNR-WARN ON/OFF of toner warning display
    -Level.1 Details To set ON/OFF of toner warning display.
    -Use case When preferring to hide the alarm until the toner runs out
    -Adj/set/operate method
    1) Enter the setting value, and then press OK key.
    2) Turn OFF/ON the main power switch.
    Display/adj/set range 0 to 1
    0: Display, 1: Hide
    Default value 1
    Related service mode COPIER> OPTION> DSPLY-SW> T-LW-LVL
    Timing to display the Toner Container preparation message:
    COPIER>OPTION> DSPLY-SW > T-LW-LVL (Level2) 5% to 100%
