falah taan
  • falah taan
    • Feb 2013
    • 67
    falah taan
    hi evryone pleas ihave panasonic 8016 when turn it on error on screen (add paper) and the try is full paper pleas any one have solve --- thanks
  • Luther
    • May 2006
    • 682
    Re: falah taan
    remove the paper tray and check for paper inside the machine, it is saying add paper because the tray isnt lifting
    • laitang
      • Nov 2012
      • 627
      Re: falah taan
      Use service mode F9-06-04 to reset LBP fuser error
      The lift motor get no matter!
      Good luck!
      • Nutstar
        • Mar 2011
        • 110
        Re: falah taan
        lol.
        also probably printing LTR when he has A4 in the tray. very common and annoying issue.
        • falah taan
          • Feb 2013
          • 67
          Re: falah taan
          Good luck!
          thank you i do that but 04 i dont no how can i know rom adresse at the end of that i switch off -on but error code u90 appear replace battery
          • DAG COPIERS & COMPUTERS
            • Oct 2010
            • 860
            Re: falah taan
            Listen & Learn; did u see teckat's post above? You'll easily get helped if you post your problem in the right forum, which in this case is the 'Panasonic' forum.
