Canon IR C2030 error E020-0350
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    Can anyone help with a Canon IR C2030 with error E020-0350?
  • MunsterTech
    • Sep 2014
    • 381
    Re: Canon IR C2030 error E020-0350
    Hi, this is a constant problem with these machines, not so much the 20 series but the iradvc22 series...i had a similar error, replaced the drum, no good, replaced the laser, no good, replaced teh toner motor , no good still same errror, tried everything, swapping the chips on the drums, upgrading firmware, turned out to be the DC controller, yours looks just like a drum issue, try it and see, but the manual says below...
    ATR patch failed to be created correctly or Patch Sensor
    error
    Detection
    High density for the target at patch detection
    Remedy
    2. Use your hand to check if the shutter of the Registration
    Patch Sensor Unit can be open.
    3. Check if the window of the Patch Sensor (UN43/ UN44)
    is soiled.
    4. Check scar on the ITB.
    5. Check movement of the Registration Shutter Solenoid
    (SL02).COPIER > FUNCTION > PART-CHK > SL to move
    SL02
    6. Check the harness/connector between the DC Controller
    PCB (UN09/J12) and the Patch Sensors (UN43/J4007,
    UN44, J4006).
    7.Replace the Drum Unit (Bk)
    8.Replace the Registration Patch Sensor Unit
    9 Replace the ITB Unit.
    10. Check conduction of the fuses (FU5, FU8) in the DC
    Controller PCB (UN09).
    11. Replace the Primary Transfer High Voltage PCB (UN04)
    12. Replace the Developing High Voltage PCB (UN07)
    13. Replace the Primary Charging High Voltage PCB (UN06)
    14. Replace the Auxiliary High Voltage PCB (UN08)
    15. Replace the Replace the DC Controller PCB (UN09)
    • jonbonse
      • Jun 2009
      • 737
      error
      Detection
      Remedy
      is soiled.
      SL02
      UN44, J4006).
      Thank you!
      Is there a bulletin about this?
