E0007 before and after film replacement! Reset a couple times in "Function" machine does not seem to be resetting?? Error - log shows E0014 before E007
Replaced film sensor.
E014 is fuser binding. Lower roller and bushings? Did you clean heater element good and regrease or did you replace whole upper assembly? Never had a problem with those, pretty straight forward. Turn fuser motor by hand to see if it turns smoothly.
