I have iR 5075. Recently I added finisher that's belong iR6570. When I connect it to iR5075 the finisher jams. Then I changed the controller PCB of finisher, then it's OK, but the papers comes out skews. My question: is it finisher iR6570 can be used in Ir5075?sorry if my english is not good. thank you
Finisher Problem
Re: Finisher Problem
Hi yea its the same finisher i have one for ir5075 and i used it at ir6570check on the service mode the jam code ,this finisher never made any problems just there are a 2 sponge rollers similer to the pick up of ir3570 these rollers on the long time loosing so change it use the pick up roller of the ir3570 u need 2 1/5 of it its a trick way .
Distinguished road makes you jewel in rough -
aha okay , but in my conclusion its similar to Canon ir8500 and IR9070 same finisher can work on both ,i dont think the machine speed effected the finisher if iam not wrong ,waiting our collages suggestions .Distinguished road makes you jewel in roughComment
