Canon IR 7105 horrible static problem
  • landspeeder
    • Feb 2010
    • 355
    We have this copier that jams and usually we find 3-5 pgs almost on top of each other in the fuser area. When pulled from the fuser the pages are clinging to each other...static cling. Also all feed/sep rollers etc. have been changed...does this copier have a way to get rid of static from the paper...or any ideas?? Help we are getting roasted from the client as being borderline useless
    Thanks!!
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • mramlawi
    • Jul 2011
    • 838
    Re: Canon IR 7105 horrible static problem
    Thanks!!
    hi ,
    this is happen occasionally looks like Transfer Corna issue open the front cover and watch the paper if its flying when shes moving under the head and the transfer ,theres some adjustment on the service mode let you increase the push of the transfer corona u can adjust but i forget whats it actually ,change the Transfer corona assembly and check.
    Distinguished road makes you jewel in rough
    • Rachid.Akli
      • Oct 2011
      • 595
      Hello,
      If the case is different from the above reply and if you think that there is a multiple paper sheet pick-up, then you can increase the separation spring tension.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • Canuck
        Tech Specialist
        • 1713
        Rewire transfer/sep,clean inside transport belts,check metal transport drive gear on back of transport drawer,check for broken tab on ufr roll gear,check gear on fixing motor(2 stage gear...they strip). As you can see there are numerous reasons why this could be happening. What is jam code? 010A 0r 0109 possibly. I've never had a static issue in reg drawer. Something else is wrong
