CANON IR6000 E100-001
  • ashish kumar
    • Jun 2013
    • 26
    [Error Code] CANON IR6000 E100-001
    Pls help me to solve this..
  • teckat
    • 16083
    Re: CANON IR6000 E100-001
    E100
    It is indicated if the BD signal is not detected within a specific period of time after the laser has been turned on.
    E100
    Main Cause =The BD PCB is faulty. The laser unit is faulty. The laser driver PCB is faulty. The wiring is faulty (short circuit, open circuit). The DC controller
    PCB is faulty.
    0001 = In 100 msec after the laser drive signal has been generated, the BD signal is not detected 50 times or more within 40 msecs.
    0002
    = While the laser is on, the BD signal cycle is found to be outside a specific range 10 times or more.
    BD PCB
    1) Try replacing the BD PCB. Is the problem corrected?
    YES: End.
    Laser output
    2) Try replacing the laser unit. Is the problem corrected?
    YES: End.
    Laser scanner unit, DC controller PCB
    3) Try replacing the laser unit. Is the problem corrected?
    YES: End.
    NO: Check the wiring; if normal, replace the DC controller PCB.
    • ashish kumar
      • Jun 2013
      • 26
      Originally posted by teckat
      E100
      E100
      PCB is faulty.
      0002
      BD PCB
      YES: End.
      Laser output
      YES: End.
      YES: End.
      i hv checked all the things every thing is fine then also error comes
      • teckat
        • 16083
        did u replace anything
        • ashish kumar
          • Jun 2013
          • 26
          yes i have replaced dc controler laser
          • teckat
            • 16083
            did u check supply voltages & for proper ground wiring
            • Brian8506
              • 1665
              DC Controller or laser? 2 separate parts
