Canon ir7105 e000110-0000
  • mramlawi
    • Jul 2011
    • 838
    Dear all ,
    i have canon ir7105 giving me error some times and times
    i changed the laser unit
    also i change the door switch and i cancelled the laser shutter and still the error occur can any one help me if theres more things must do also if theres any adjust must do when i install a new laser .
    thanks
    Distinguished road makes you jewel in rough
  • vigour
    • Aug 2010
    • 1038
    Re: Canon ir7105 e000110-0000
    Check if you are losing 24V , caused by main motor or some other motor
    • mramlawi
      • Jul 2011
      • 838
      Do u think its a motor problem it just happen when i try turn the machine on it made the problem or when i open the door then after clear it works
      • toni anas
        i have experience in canon type like ir7105 that is ir105... it same problem, the problem is output 24v is losing from power supply unit... check the output voltage from PS Unit !!
        • mramlawi
          • Jul 2011
          • 838
          so should i change the power supply ? sorry but im puzzled PS u mean to check the power supply of the machine ?
            Product : imageRUNNER 7086 / 7095 / 7095 Printer / 7105
            Title : E110-0000 when machine goes into high speed rotation.
            Error :
            E110-0000 when machine goes into high speed rotation. Machine will also lose the 24vdc and 38 vdc at this time . If you go into service mode, machine will go to ready and you can check motors, clutches and fans but when you exit you will get an E025-0001.
            Workaround :
            Replace the separation fan, M13 . Part number is FH6-1942-020. Found that if we ohmed the blue and red wire going to motor it was aprox 15 ohms a good one should read aproximatley 6k OHMS
            Product : imageRUNNER 7086 / 7105 / 7095 / 7095 Printer
            Title : Error Codes E840, E732 and E110
            Problem :
            When the machine is turned on it will display an E840, E732 or E110 error code
            Solution :
            A poor connection at the machine relay board can cause erratic error codes. Unplug and reseat all of the connectors on the relay pcb. Pay close attention to connectors J7101 and J7104.
            Product : imageRUNNER 7086 / 7095 / 7105
            Title : Intermittent Error Codes E840, E732 or E110
            Error :
            Intermittent Error Codes E840, E732 or E110 are occurring at the power up sequence and during a copy job. It was noticed that the normal vibration of the machine would cause the front door to momentarily pull away from the magnet catch.
            Workaround :
            In this case, the Magnet Catch was not properly holding the front door closed. After replacing the magnet catch the issue was resolved.
            The part number for the magnet catch is XZ9-0251-000. (Figure 120, Key Number 5)
            • mramlawi
              • Jul 2011
              • 838
              unable to solve the problem :/
              the machine still giving the error e000110-0000 i noticed that the error occur when my client scan the a book and when he want to press done on the screen the error occur ,some times the machine make around 4000 copies and after that the error occur really im dizzy from this werid problem ,i havve changed the pcb relay baord and also the power supply ,Dc board ,laser , door swtich ,primary corona shutter everything and nothing solve my problem :/
              • Canuck
                Tech Specialist
                • 1713
                Have you replaced video pcb or at least reseat its connectors? I see you have replaced the door switch also..make sure that the actuator on the door is actuating it properly and fully...sometimes gotta twist front door to "reform" hinges so that door closes flush and properly.
                • mramlawi
                  • Jul 2011
                  • 838
                  Hi,
                  which video pcb u mean ? The door is totaly lock my friend .about the connecters everything is alright and all the connecters are setted correctly
