Canon IR2300 Copier
  • RonMac
    • 57
    [Error Code] Canon IR2300 Copier
    How do you reset error code E000? Thanks. Ron
  • JPiek
    • Oct 2014
    • 435
    Re: Canon IR2300 Copier
    E000 looks a bit weird, only general info i can find is the fuser not heating up...
    You can clear an error in servicemode Copier-function-clear: error...
    If the fuser or any other part is faulty, it will return though...
    Johan
    • laitang
      • Nov 2012
      • 627
      Enter service mode then:
      COPIER>FUNCTION>CLEAR>ERR.
      • RonMac
        • 57
        Thanks, I tried that so the fuser or other part is faulty. Ron
        • JPiek
          • Oct 2014
          • 435
          Does it warm up, or even print ?
          Johan
          • RonMac
            • 57
            Thank you...I did try that but it keeps going back. Some part must be faulty. Ron
            • RonMac
              • 57
              No it does not....any suggestions? Ron
              • JPiek
                • Oct 2014
                • 435
                If the 2300 keeps "Warming up" let it sit for a while, then remove the fuser or just open the door. If the fuser isn't hot, i think you should replace it... If you have another 2300 you could swap fusers to test...
                Johan
                • RonMac
                  • 57
                  Ok I will try that and see how it goes...thanks so much. Ron
                  • JPiek
                    • Oct 2014
                    • 435
                    Check the fuser temp under Copier-Display-Analog :
                    FIX-C Temperature of the fixing roller surface (Detection temperature of the main thermistor) 1
                    FIX-E Temperature of the fixing roller surface (Detection temperature of the sub thermistor ) 1
                    FIX-E2 Temperature of the fixing roller surface (Detection temperature of the sub thermistor 2)
                    oh, btw what does COPIER>COUNTER>DRBL-1 say about the fuser/fixing ?
                    Johan
                    • RonMac
                      • 57
                      I will check the above and get back with you. Heading back to the shop and taking a fuser with me, just in case. Ron
                      • Dutchman
                        • Jan 2011
                        • 58
                        Error E000 is temp related.
                        Clean the main ans sub thermistors, also check the connector. Failing that you would have to replace the Fixing film unit and still clear the error in service mode or replace the DC controller pcb.
                        • RonMac
                          • 57
                          Ok will check that all out and thanks so much. Ron
                          • RonMac
                            • 57
                            Got the 2300 up and running. Thank you. Ron
                            • RonMac
                              • 57
