I need a good drum...my contract has 3 little dots > . < that small and they want the drum changed and anybody with a decent drum that wont leave marks
You never realize how cheap a professional is until after you let an amateur do it.... and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
Make sure nothing is arching to cause those spots.
Clean or replace ALL OZONE filter periodically. Interest should be taken to clean fan duct of dirty filters.
Check transport duct for damage.
It has been noted that the transport fan duct may become damaged or cracked. These leaks allow intermittent spots to occur when toner is blown back onto the sheets passing fan duct.
Check transport fan duct seal. The seal is located inside of the iR105.
The seal should not be torn or damaged.
If damaged, replace immediately to maintain proper air flow and operation of machine.
Not all foam seals are available in the parts catalog.
Foam weather stripping from a hardware store may be used as a substitute.
Thanks for the info but I found three little chips in the drums surface...can they be somehow fixed.......so much $$$ for 3 little marks.....also we need a laser for the same model of machine, IR7105, do you have one?
Thanks!!
Nail polish is a very good advice, you should also check the state of the coronas and be sure to reset the corona counters in service mode. This is very important on this model because the process control use among others the counter values to adjust the corona current. New Wires without resetting the counter can lead to arcing on the drum surface and might leave permanent damage. I have said this before, but this can not be overstated. Btw.: same to the IRADV 6xxx and 8xxx series. So take care.
If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
What is the abbreviation for the corona counters in service mode...where would I find it...we just happen to be changing the wires today and didnt know this and it makes sense!!!
Thank you very much!!!
Oh gotta manual...but its the service managers project and he isnt good at reading ...duhhh...he is the guy that left two screws near a dev assembly and wondered where they went and why there was a scrapping noise and two vertical lines on the copies...few years ago..I think I mentioned it
Oh by the way thanks...and I will text him with the info
You could try some clear nail polish on the 3 chips.
On 7105... VD is about 450v, VL is around 75v..nail polish spot= zero primary charge on the polish(VL=0). Laser writes black on this machine....so....nail polish=black dot.
White Out or White Nail Polish_?
In my 7095, 3 + 3 black dots... the length increases .... What is it? Is it because of arc? Nail polish trick will work? sample attached... kindly help any one...
Are u a tech._?
If so> what have u inspected so far_?
Drum , Coronas, Filters, etc.
Last time maintaince was performed_? or parts replaced_?
Printer environment_?
Dots too close for it to be a drum. Do some math......diameter of roll= circumference(distance between spots) divided by pi(3.1415)
