Canon image RUNNER Advance 2020i
  • lawdar73
    • Nov 2014
    • 7
    I have a machine Canon iRAdv2020i and requesting a black toner i changed the toner and still saying please replace black toner. i dismantled cleaned everything and re assemble again machine is still asking please replace toner black.I know there was a service bulletin regards to the black but this is when it gives you an error E020-0x60 but i have no error codes coming upany advise please???
  • teckat
    • 16083
    Re: Canon image RUNNER Advance 2020i
    Canon OEM Toner
    COPIER > Display > DENS > DENS-K = what is reading ??
    COPIER > FUNCTION > INSTALL > SPLY-H-K
    [START] is displayed in the blank field instantaneously, and [OK] is then displayed.
    Open/Close the front door and insert the door switch tool into the door detection switch.
    *The copier immediately starts supplying toner to the buffer.
    *The toner supply operation is completed within 40 seconds.
    (During this period of time, check to see if the toner bottle rotates intermittently. If the toner bottle
    does not rotate, suspect another problem is occurring.)
    • lawdar73
      • Nov 2014
      • 7
      Originally posted by teckat
      Canon OEM Toner
      Hi thanks for your reply, I will try to do so tomorrow and will let you know the out come The TONER IS OEM yes
      • lawdar73
        • Nov 2014
        • 7
        Canon OEM Toner
        Hi,
        I checked everything as said the Dens -K -2.00% did all the procedure but the problem is that the toner bottle is not turning.the problrm is that the screen is saying Insert toner cartridge and it changes to replace toner cartridge, could it be the sensor that detects there is the cartridge inside or not? and that is why it not turning???
        thanks
        Lawrence
        • teckat
          • 16083
          Hi,
          thanks
          Lawrence
          Toner Cap Opening
          A cap of the Toner Container is opened/closed in conjunction with opening and closing the
          Toner Container Cover.
          Toner Container Detection
          Presence/absence of the Toner Container is detected.
          There are the Toner Container Switches (SW8 to 11) as shown in the figure below and they
          are pressed when the Toner Container is set so that presence of the Toner Container is detected.
          • lawdar73
            • Nov 2014
            • 7
            ================================================== ====================Toner Cap OpeningA cap of the Toner Container is opened/closed in conjunction with opening and closing theToner Container Cover.Toner Container DetectionPresence/absence of the Toner Container is detected.There are the Toner Container Switches (SW8 to 11) as shown in the figure below and theyare pressed when the Toner Container is set so that presence of the Toner Container is detected.[ATTACH=CONFIG]27243[/ATTACH]
            Hi again, sorry i did not answer earlier but i was so busy, regards to this problem it is now solved i dismantled the container where the black toner is and the detection leaver was jammed cleaned the switch with alcohol re assembled and worked ok thanks for your help my friend
            • teckat
              • 16083
              :-) welcome, have great day 😎
