actually its waste toner is full n have checked all the things than also some gear is making noise bt i dnt nw where its coming frm. any wuld suggest me pls how to solve this.
canon ir 6570 is making noise
Re: canon ir 6570 is making noise
To find the origin of noise in a copyer is a pain in the a**, so much mechanical parts that turn, clutch or whatever
I normally try to find the source by putting my ear against the different sides of the printer while it's making the noise. If there a multiple parts behind the panel i often use the mechanic's way to find noise in a car-engine : Put a large screwdriver with it's metal agains the suspicious part and the handle agains my ear. You can hear or feel it that part is the correct one.Johan
