Canon İR 2270 photocopy machine printer problem
  • funnestfan
    • Feb 2013
    • 7
    Hello.
    We have Canon ir 2270 photocopy machine. We have a problem. Machine is good but when we connect with usb or network cable for using printer, machine doesnt work. On the screen message 'check the network connection' then i connect the network cable, message doesnt appear. Every thing is okey then when i sent to print file machine is recieving data(on the screen "recieving") but doesnt work.
    Where is the problem ? i think this problem about to hard disk or mainboard or bootrom ? which one is broken?
    Thanks a lot
  • Luther
    • May 2006
    • 682
    Re: Canon İR 2270 photocopy machine printer problem
    sounds like a driver problem
    • copier tech
      • 8163
      First try printing from a laptop & crossover cable, if that works you know the copier is ok.
      Also try updating the firmware this can cause odd faults like that.
      • victor_v
        • 71
        The device printed on a network earlier?
        If isn't present, whether check is in the device OPTION of the network printing. By default iR2270 the network printer isn't.
        For the printing on a network it is necessary to set:
        UFR II print function ==> UFR II Printer Kit-E3 (P BootROM) + iR System Expansion Kit-A1
        UFR II/PCL print function ==> Printer Kit-E2 (H BootROM) + iR System Expansion Kit-A1
        UFR II/PCL/PS print function ==> Multi-PDL Printer Kit-E1 (N BootROM) + iR System Expansion Kit-A1
        Good luck
        Hardworking people are not present. Simply many it is boring to idle.
