I have a Canon c9075 advance yellow reg is off. Cleaned, ran init-itb, quick adjust. No help. Any suggestions?
color registration off ( yellow)
Re: color registration off ( yellow)
Each color laser unit has a tilt correction lens and a tilt correction motor, maybe the one in the yellow unit is stuck. Try COPIER>FUNCTION>LASER>LD-ADJ-Y/M/C to set them in the initial position. Look at the alarm codes, if there is a 34-0004, the cout value of skew correction motor exceeds specific.
To hunt the error down, you can interchange yellow and cyan laser and see, if the error goes to cyan.If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
