Canon IR7095 laser problem
  • landspeeder
    • Feb 2010
    • 355
    We have a contract machine, IR7095, with a weak laser...the assembly is quite expensive to buy and I was wondering if anyone has had any success in rebuilding one.
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • Corder
    • Nov 2014
    • 105
    Re: Canon IR7095 laser problem
    Are you sure that laser is weak or maybe it's just dusted LSU mirrors/lenses? Or you cleaned them up already?
    • V-P
      • Apr 2011
      • 679
      I think now you can order the diode as a separate spare part.
      FM2-8146
      • landspeeder
        • Feb 2010
        • 355
        Its really clean...I forget the error it threw...the service guy working on it is on call. He said the error was a weak laser. If we could get that diode and that works ...that would be awesome!!!!
        Now to see what I can find!!
        FM2-8146
        • Canuck
          Tech Specialist
          • 1713
          Laser diode will fix it. Very common on 7095/7105
          • Herrmann
            • Jan 2006
            • 792
            just a head up about laser issues on this box, there was a techincal info long time ago about sparking due to less insulation of a contact going from the sep corona hv contact to the fuser assy, if i remember correctly. The upper fuser roller of this model gets a HV support from the trans/sep corona to avoid sticking toner on it. Before going to change expensive laser parts, have a close look to the hv wiring to the fuser and check also, if the upper fuser roller is isolatet in its bearings and connected properly to the hv.
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • V-P
              • Apr 2011
              • 679
              I think I am in this exact situation which Herrman explained.
              I did check everything located on the frame assy (the one that slides out). Checked the fuser area and the sep corona, but I believe my fault is in the back of the machine.
              Since I am a lazy person : Has anyone had this issue and has a short cut like "Look exactly here" so I don't have to remove all the back of the machine to check all the wires ???
