Ir2200 Copy quality issue
  • jake24482
    • Apr 2011
    • 116
    I am working on ir 2200 it is putting shadow on copies through adf only .internal print.pc print.copies from glass are fine .when customer scan or make copies using adf there is shadow on top of the page i clean all the optical nothing changes . please if someone can help with this issue .
    thanks in advance
  • canon33
    • Jun 2014
    • 65
    Re: Ir2200 Copy quality issue
    Check Df height. Maybe lower it? Also make sure white platen cover is on.
    • jake24482
      • Apr 2011
      • 116
      every thing looks normal
      • doug
        • Dec 2011
        • 198
        thanks in advance
        Hello There, Make sure doc. feeder is not skewed or it may be the feeder is not sitting flush on the platen.....try new doc. feeder hinges to make sure feeder is flush.
        Hope this helps,
        Doug
        • jake24482
          • Apr 2011
          • 116
          Hope this helps,
          Doug
          every thing looks good even i replaced it with an other still doing same thing
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5002
            Scanner is not in the right position when it should be during ADF scanning.
            • jake24482
              • Apr 2011
              • 116
              i looked very closely did not see any thing lose or abnormal it just fine from glass no issue at all but when they scan it show that shadow on back edge .
              • jake24482
                • Apr 2011
                • 116
                It was scan lamp
                • zoraldinho
                  • Mar 2008
                  • 5002
                  Interesting.Copies from glass are ok!?
