canon clc 3220
  • aminedbk
    • Jun 2025
    [Misc] canon clc 3220
    i have a strange problem with my clc 3220 error code for black dram
    i change the dram with an original one it print about 50 A4 color
    then i have a (flou) like a duplicate black color i made a gradetion
    became ok for 10 copies and need gradation againe
    can please any one help me thanks
  • teckat
    • 16083
    Re: canon clc 3220
    Remove ITB, clean or replace underside of sheet, clean the large black rubber roller.
    Put back the ITB>
    Then do a Reg-clear in service mode level 2.
    After clearing, run quick autogradation then full adjust.
    * If this does not work do a dc-cont clear in SM level 1. Always run a P-Print before clearing any of the control boards.
    After clearing dc-cont, turn off copier, open front door, turn on copier, re-enter info from P-Print or from door specs (in cover inside front door. Restart copier, run autogradation.
    Then print out type 6 test page and check to see if all colors are uniform.
    • aminedbk
      Re: canon clc 3220
      i clean the ITB
      and i enter SM and do a D con clear
      all is good now
      tanks for help
      • teckat
        • 16083
        Re: canon clc 3220
        Originally posted by aminedbk
        i clean the ITB
        all is good now
        tanks for help
        good,thank you
        ?? did u remember to put back the P PRINT SPECS
        • aminedbk
          Re: canon clc 3220
          YES my friend thank you
