Canon w6200 error code eo2do2
  • toshiro
    • Aug 2025
    hello. I bought a canon w6200 that had been sitting in storage for number of years. The machine looks pretty new inside the rollers look like it has had very minimal usage but it gives error code eo2do2 which after researching i found it is the carriage home position sensor. As soon as the carriage returns to home position and touches the chps sensor i get the above error. Also it will not load into 'service mode' if i hold online and paper feed button while powering on nothing happens. Is there anyway round this ? Any help will be much appreciated. Thank you.
  • teckat
    • 16083
    Re: Canon w6200 error code eo2do2
    There are two ways to enter the Service Mode on the Large Format printer:
    1) For models with an INFORMATION button:
    - Turn on the printer while holding down the PAPER SOURCE & INFORMATION buttons.
    - Keep pressing the buttons until the letter "S" appears in the upper right corner of the display.
    2) For Printers that have LOAD and NAVIGATE buttons:
    - Turn on the printer while holding down the LOAD & NAVIGATE buttons.
    Note: To exit Service Mode, turn off the power.
    In order to clear an error code, simply enter and exit Service Mode. The machine will clear the error just by entering Service Mode. There is no need to initialize anything while in Service Mode.
    • toshiro
      Thank you for your reply teckat , my machine does not have an info button but i will try holding down the navigation buttons and see what happens tomorrow when i am near the machine. Thank you so much.
      • teckat
        • 16083
        E02D02
        / Carriage home position error
        This is displayed when the carriage home position / head height sensor could not detect the carriage within the prescribed time.
        <Probable problem locations>
        Foreign object in carriage contact section, carriage home position / head height sensor, linear scale, linear encoder, engine controller, system controller
        1. Visual check
        Remove any foreign objects adhering to the carriage contact section, carriage home position / head height sensor, linear scale, and linear sensor.
        2. Carriage home position / head height sensor
        Check operation using SERVICE MODE>I/O DISPLAY, and replace if anything does not function normally.
        3. Cable connection check
        Replace the cable between the carriage home position / head height sensor and engine controller if the connection is not functioning normally.
        4. Replace the linear scale.
        5. Replace the linear encoder.
        6. Replace the engine controller.
        7. Replace the system controller.
